LinkBack Thread Tools Rating: Thread Rating: 10 votes, 4.90 average.
boostfix's Avatar
Hey Roland...you must have a friend with the SBB car maintenance department
Looking real nice!
Dan
88 930 blk/gry
Old 06-20-2016, 08:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #561 (permalink)
proffighter's Avatar
Long time since, but...
Still nothing new worth to share. While still working on my insulation (not much motivation for that job, not the result) I am looking for other things I want to add maybe:
1st is the ER quick change bla bla X-Brace:
Elephant Racing 935 X Quickchange Strut Brace ERMP2162200 - Elephant Racing - ERMP-2162200 | Pelican Parts
As I have already mounting points, I only would buy the cross, unfortunately only available with brackets etc... Because my points are not at same point, I have to cut away about 20mm at each end and recut threads inside. Does anybody has that brace installed? Wonder if there is enough beef inside for threads?
2nd I saw that Rothsport oil check valve. Makes sense, but is there really an advantage or just in case of leakages?
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
3rd This fire extinguisher mount:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2014.cgi?SUPERCAT_FLAG=Y&make=POR&Context_make=&please_wait=N&LastVisited_input=911M&Previous_Section=&forumid=8&threadid=&LastVisited_input=911M&make=POR&description_side=BK-R-9530+&GoSearchSideFlag=T&command=DWsearch&command=DWsearch&REFINE=Y&FORUM_REFER=&SUPERCAT_FLAG=Y&Previous_Section=&LastVisited_input=911M&make=POR&description=BK-R-9520+&GoSearch_side.x=0&GoSearch_side.y=0
Is it free of play, no noises, rattling etc.? Other issues like poor clamping force?
Any experiences?
Roland
930 Turbo '81 Too many modifications to list
Old 09-05-2016, 05:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #562 (permalink)
Max Sluiter
Flieger's Avatar
I have an extinguisher, not that same mount, but the rattle is not from the mount it is from the handle (trigger) on the extinguisher itself.
Old 09-05-2016, 12:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #563 (permalink)
sladey's Avatar
I've got the elephant racing cross brace - very happy with it.
At the front it relies on screwing through to some substantial (3mm thick?) backing plates that go the other side of the body panel - in the inner wing. So it isn't screwed into the inner wing, it's effectively clamped to it and very strongly - the inner wing is sandwiched between the two elephant racing brackets.
I've no idea if you could cut 20mm off and re-thread it - you'd be better off asking Chuck at Elephant Racing. However if you do then you're also moving slightly the point at which the two struts join each other - don't know if that would cause a problem.
IMHO I would suggest if you fit it then fit what they supply in the way that they supply it
The simple things you see are all complicated;
I look pretty young but I'm just backdated
Old 09-05-2016, 11:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #564 (permalink)
Even if not what I was looking for, nice input to have a look at
Roland
Old 09-06-2016, 12:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #565 (permalink)
I know how the brace is mounted, no doubt it's fine. There are two reasons for me not to use the delivered brackets.
First, I have already mounting brackets welded in earlier (see pics fresh out of paint cabine), they will also conflict with the other ones.
Point of joint (ha what a nice term) will not be different, only angle, but there is no issue. BTW I asked Chuck already, just wanted to see, what others may think.
Second, I have a strut bar which I like very much and therefore I cannot use the rear brackets of the ER strut.
Originally, I wanted to make my own strut, but this would be quite big effort, because I like the Idea of the adjustable ends there to set a little strain.
Roland
Old 09-06-2016, 01:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #566 (permalink)
Kozmo930's Avatar
I have to check in once in awhile , nice to see everyone else is busy in life but your car is totally to clean Roland . Keep up the slow steady progress it will finish itself one day ...
Kozmo
Old 09-19-2016, 09:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #567 (permalink)
Kozmo
That's what I am waiting for
Roland
Old 09-20-2016, 03:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #568 (permalink)
While still waiting for my X-Brace from Heigo (more later) I received some pieces. Rubber, seals etc. and a R-9530 Quick Release Fire Extinguisher Mount. Earlier I bought the SPA Extreme 1kg Novec 1230 extinguisher.
Of course I had to save some weight here too:
Drilled the handles and made an aluminum pin
I bought the bigger one (90mm) version, because the bottle diameter is 80mm (small mount has 76.2mm / 3"). I used hard rubber to fill the gap. As I am not really happy, I ordered now the smaller one too, plan to machine the clamp to fit my extinguisher...
However, let me show some details I don't like (some of you might think I am an awkward guy, but that's what I am expecting in that price range.)
First I cannot understand, why the drillings are so close to the corners, bevels sometimes cut therefore
There are machining tracks where there should not be:
One of the biggest issues besides the finish is the machining broke through into drilling, right one visible here, but left is affected too
This is probably due too much heat when anodising / gas and therefore acid acting instead of anodizing
Poor finish here too, no parallel surface and brow at the side
Roland
Old 10-12-2016, 12:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #569 (permalink)
Review second mount
Today I received the smaller mount. All in all the same issues, but some diffences too, just wondering about
Handle anodized at the smaller one, clamping parts and centers not. Bigger one vice versa. on the raw parts machining quit visible (compared to the anodized parts which are satined)
small machining fault vs. bigger one at the clamp (note: same measurements, so no reason for diff, make me think of different suppliers)
Roland
Old 10-13-2016, 09:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #570 (permalink)
Love your attention to detail! Thanks for pointing out the shortcomings on the brey-Krause parts. Great stuff, and really enjoying what you are doing!!
Old 10-20-2016, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #571 (permalink)
After machining some weight off the BK mount and increased clamp diameter, it's ready for test fit (to compare I made pic of the bigger mount to:
Roland
Old 10-22-2016, 02:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #572 (permalink)
Main reason I choose a smaller extinguisher was is size. So it will fit on the tunnel in front of the shifter. First I had to install some Tubtara nuts:
Mount base fits
And finally the complete thing, like the result very much
Now back home, because the shifter and handbrake lever are black, I willanodize the mount black too
Roland
Old 10-22-2016, 02:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #573 (permalink)
Nice to see some progress, gives me hope for mine!
Very, very clean
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 10-22-2016, 03:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #574 (permalink)
Great work!
Iain
1970 911E, 2018 911GTS
Old 10-22-2016, 08:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #575 (permalink)
Anodized, bolts machined for a bit weight save and nicer finish. Ready to assemble (little detail: Plastidipped the springs to avoid scratching and noise)
And the final result. Looks even better than I imagine before
Roland
Old 10-23-2016, 05:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #576 (permalink)
A couple of weeks ago I decided to buy an x-brace for the trunk. First I checked the ER. Not bad, but not fitting out of box (I already have mounting brackets welded-in). Further I like it a bit more beafier there. So I asked Heigo, who made my cage too. They are one of the most expirienced regarding cage etc. here in Europe and an old Porsche near brand, still all made in Germany. I was really suprised, that an individual piece made according my measurements was only a couple of Euro more than the ER x-brace. Of course I had to wait for, but here it is, very nice piece
I have do drill the brackets to bolt down, made only M8 holes to have all options then.
As my hunger for weight loss never stops, I bought some lighter battery terminals too. Almost half the weight of the massive copper ones before. Also I like the look and the fact, that the cable can be crimped. This leads me to the problem I did not expect before: No one of the vehicle electricans seems to have this F-type crimping tool... Maybe I will be lucky once, otherwise I have to make my own crimping matrix.
However Hollow drilled and machined head of the bolts too:
Roland
Old 11-01-2016, 01:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #577 (permalink)
I often thought about making a new wiring harness, even I did this about ten years ago already. Reason is mainly that I not used automotive wires then (which will not be a problem I guess) and much too thick wires, almost all are 2.5mm2 and more. Quite a lot of copper weight to save here. Further I want to make a new fuse box and relay holder.
First I worked on the fuse boxes, replaced the huge nuts by Tubtaras:
Lots of wire and connector I will need, here just a few I have:
Roland
Old 12-29-2016, 04:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #578 (permalink)
After many hours of bending, grinding and drilling the finished item, of course with hollow drilled bolts and aluminum Tubtaras
Roland
Old 12-29-2016, 04:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #579 (permalink)
Kozmo930's Avatar
Nice work as always Roland , good to see you have still had some steady progress through the winter . I'm back out of the brace after another surgery on my hand and at it again in the garage myself . May have a finished product for you in the near future , wish me luck.
Kozmo
Old 12-29-2016, 11:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #580 (permalink)
