New 930 4speed gearbox parts
Here's some pics of the parts needed to refurb & upgrade the 930's gearbox
![]() ![]() ![]() I've got a pro doing this for me cuz I don't have the knowledge or tools and he has plenty of both
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Homemade M8x1.25 thread chaser
Needed to clean out some cam tower threads. If you don't have a collet stud holder you may wanna consider chasing down the Snap on van cuz it's one of the best tools I own
PFM
Captain,
Do y0u have a part number for that cool tool? Collets I have that tool I do not.
Stay Tuned, PFM |
Snap-On collet housing part#
The collets I have are M10x1.5 for head studs part# CG500-43 and part# CG500-37 for M8x1.25 collet for most engine studs
Looking good Rick. Glad to hear you got an expert on the tranny, even a four speed can be quite the jigsaw puzzle to put back together.
Have you already put the squirter rods back in the cam towers? If so were they hard to get back in? Here are a couple of video updates on my progress of spending my porsche bucks, lol. ![]() CAD/CAM work for a heat exchanger component: CAD/CAM Demo - Gas Tube Core - YouTube CAD/CAM work on an art related birthday gift for my daughter: My First CNC Artwork - YouTube |
I've got the 4 plugs ready to go, but haven't put the 2 squirters in the cam towers yet. What would you use to glue those plugs in there, triplebond 1104 or Locktite 574? I used the orange locktite 574 on the towers to the heads but it never seems to dry ![]() Thanks, RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 08-17-2011 at 08:55 AM.. Reason: spell |
There is a pin on the oil fitting that keeps the rod oriented, so any good anerobic sealant to plug the gaps between the rods and towers should do the trick.
The stuff that oozes out shouldn't harden since it remains exposed to air, but if you were to take your towers back off you should find that the areas in between the contact surfaces have hardened. I know you still have quite a bit of work ahead of you, but have you decided on what turbo you are going to put on there? |
Turbo choice
![]() Yes, I have made the turbo choice and here's a hint as to what it's gonna be ![]()
Garrett GT3578R
here it is: Garrett GT3582R Twin Scroll Turbo - Full-Race.com
Whattcha think? Could there be 500 Hp hiding in it???
Good choice, I had been thinking about that one as well. If memory serves me correctly the cartridge might need to be tweaked since I think that unit is water cooled.
![]() I'm also considering this Borg too, so let me know what you think! BorgWarner S300SX 8375 Turbo S360 - Full-Race.com
Turbo
After much debate I finally narrowed my search down to just two that were both great fits on a twinscroll 500hp EFI 930. The two that were listed above are the Garrett GT3582R and the BorgWarner S300SX 83-75.
The BW won me over due to it's dependable journal brg with oil only cooling setup. The fact that it can make up to 310 ft-lb of torque at 2000 rpms and 5 psi of boost helped me with my decision as well as the potential to make 487 ft-lbs at 4000 rpm at 15 psi of boost...hope I can keep it between the ditches ![]() ![]()
Sounds like a good choice, I'm a big believer in a mid sized turbo on a street motor since there you need that low and mid range grunt more than top end power and max flow.
I do hope you can keep that thing headed towards where its approximately pointed at once its back on line. That's the kind of power to weight ratio that can easily get you into all sorts of trouple, lol. Last edited by 350HP930; 08-19-2011 at 02:48 PM.. |
930 gearbox progress
pic from the the dark side
Chain Housings
Today I bolted the two chain housings to the case.
Galley Plugs Needed
Anybody know where I can source 4 galley plugs that I think are M10x1.0???
I ordered the 4 oem splash tube plugs for the cam tower, but once they arrived I realized that the holes had already been tapped, so I gotta find some plugs ![]()
Glad to see you got your hands on a R&P alignment tool. I hope that's the new lower ratio andial unit I spent over $1,200 going in there.
I could be wrong, but I thought I had a set of hollow hex plugs for those galleys in one of those boxes of fasteners I gave ya. |
PS - Before you fasten down the cam chain boxes for good, you may need to epoxy the back sides of the tensioner hardware pins. They are likely to leak through the press fit if you don't.
Don't make the epoxy blobs too thick or they will contact the cooling fins on the #1 and 4 cylinders and that would hold back the chain case from seating flush against the engine case on the back side. The mounting pins for the chain rails are also pressed into holes in the chain case and you can spread a little JB Weld over them to seal them from ever seeping oil too. Probably don't need to do those but it doesn't hurt. |
