Closed Thread
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 1.71 average.
wwest's Avatar
It seems that what he actually meant to say was that he "invented" the idea of rerouting the high side refrigerant flow path, the front lid condenser first, then to the rear lid condenser and then to the dryer.
His claim was that this technique improved the refrigerant condensing efficiency substantially, well enough to justify the expense. No qualifying of the exact or approximate level of improvement was ever offered, as was the case of an engineering explanation for the gain, insofar as I am aware.
My own measurement of CSA airflow for the 2 condensers seems to put the lie to his "invention". Even at idle the rear lid condenser gets a higher level of cooling airflow, and the equation gets worse with rising engine RPM.
"Throw" in his "improved" PFC front lip condenser and matters get ever worse, as the new condenser actually BLOCKS(***) forward motion cooling airflow whereas the factory condenser takes advantage of this effect.
*** As is the case with ALL aftermarket front lip condensers... PUZZLING, EXTREMELY so.
Old 05-10-2016, 05:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #381 (permalink)
lateapex911's Avatar
Ah, ok, thanks for the summary, thats pretty much what I had gleaned.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-10-2016, 06:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #382 (permalink)
I think one of his main features is a high performance front condenser with special shrouding and hi flow fan. He showed pictures of this somewhere. That could potentially indeed successfully dump a lot of heat away from the engine. Again, there are glimpses of ideas that may work, but no before and afters, or other comparisons.
I wish him well, but we may as well wait for Gilles to give us actual data or at least impressions.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 05-10-2016, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #383 (permalink)
Good luck,
Dave
Gilles wont release anything on his own!
Old 05-10-2016, 10:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #384 (permalink)
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
. . . PUZZLING, EXTREMELY so.
GO SIT IN THE CORNER, WWEST!!!!!!!!!!
The charlatan modus operandi continues, then - nice!
Old 05-10-2016, 11:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #385 (permalink)
tharbert's Avatar
I think I'll end this tread and not post this install here
have a nice day
Sadly, he thought again...
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 05-11-2016, 06:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #386 (permalink)
Porsche Crest
Good luck,
Dave
YES THIS REMOVES MASSIVE HEAT from the front PFC
Gills does NOT have this initially BUT IF HE WANTS ICECOLD911 @ 100 F plus ambient he will discover his OEM front blower ain't going to cut it!
AND NEEDS SOMETHING LIKE THIS!!!!!!!!!
Old 05-11-2016, 06:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #387 (permalink)
DaveMcKenz
YOUR THINKING IS WRONG ABOUT ENGINE HEAT AND WHAT IS GOING ON IN MY DESIGN!
Old 05-11-2016, 07:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #388 (permalink)
Sturmvogel
Corvus Corvax's Avatar
DaveMcKenz
Shouting doesn't make your point more clear, nor does it clarify his confusion over your design goals.
Old 05-11-2016, 08:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #389 (permalink)
Thanks, Reid.
Please clarify. My image is that you have a big honking front condenser and fan assembly that dumps a lot of heat, first. Then you have a very efficient rear PF condenser. You use an orifice valve and accumulator too. Besides control and air distribution, what am I missing?
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 05-11-2016, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #390 (permalink)
3 restos WIP = psycho
kenikh's Avatar
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-11-2016, 08:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #391 (permalink)
Porsche Crest
Thanks, Reid.
Dave
Reversing The Gases
Old 05-11-2016, 08:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #392 (permalink)
kenikh GET YOUR CRAP POST OUT OF HERE
OR I will bring back the moderators
Old 05-11-2016, 08:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #393 (permalink)
maybe its time to do this anyway!!!!!!!!!!!!
Old 05-11-2016, 08:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #394 (permalink)
Reversing The Gases
Hi Reid,
I did include the reversed gas flow, by saying you send to front condenser first, then rear condenser. That's the only reversal isn't it?
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 05-11-2016, 09:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #395 (permalink)
Hi Reid,
Thanks,
Dave
yes
Think HARDER
Old 05-11-2016, 09:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #396 (permalink)
There is basically no noticeable engine oil temp increase when the a/c is turned or off
With my design
The OEM A/C Design greatly increases oil temp when the a/c is on as ambient temperatures increase
Old 05-11-2016, 09:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #397 (permalink)
Thanks, Reid.
Dave
That is exactly correct, including all of the "secrets" that we are not supposed to know about yet do...
So, when Reid says "your thinking is wrong" he really means "you are 100% correct and understand this perfectly", just as when he says "invented" he means "didn't invent at all".
See? He makes perfect sense, once you put his posts through the Spiderman Decoder Ring.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 05-11-2016, 09:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #398 (permalink)
its unfortunate I have decided to not post the install here, you had your chance
oh well!
Old 05-11-2016, 09:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #399 (permalink)
kenikh's Avatar
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-11-2016, 09:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #400 (permalink)
Closed Thread
