wayner's Avatar
Saving a 73 from the crusher...AGAIN
Since my last thread blew up along with my motor, I thought I would start a new one.
There won't be much to report until after the new year though.
Here is the original build thread
and here is the tantrum thread
Sending the 73 to the crusher
TO BE CONTINUED...
SOLD - 914 wide body hot rod
Old 12-06-2015, 04:19 PM
wayner's Avatar
What I learned form the last thread is to add the index at the beginning. After a while you can no longer edit old posts.
Here is the index that this thread will be a continuation of.
Originally Posted by wayner View Post
Updating my thread index to include "over the top oil line."
PAGE 1 - The find - Comparing hidden surprises to a car already apart (see parcel tray comparison at bottom of page).
PAGE 2 - Engine build sheet
PAGE 3 & 4 - Transmission build sheet
PAGE 7 - Door post repair
PAGE 9 (TOP)- The engine video
Page 9 (BOTTOM) - Rolling the fenders
PAGE 11 - RSR oil cooler duct
PAGE 14 - The 17 inch wheels
PAGE 16 - Before, during and after
PAGE 17 - Headliner install pictures Also, see post 370 on this pagefor a summary of installation steps and parts list
PAGE 18 - Some RSR history starting on post 350
PAGE 21 - Oil cooler lines
(Note, over the top oil line to get around headers - see post 457 on page 23
Page 23 - Windshield trim adjustment. (I also elaborated in this thread - Window seals and trim also, the windshield trim thread that I couldn't find just resurface so I'll add it here).
Page 23 - repairing rear Sway bar mounts with WEVO mount repairing rear Sway bar mounts with WEVO mount but I would do it this way if I had to do it again need sway bar ideas
PAGE 24 - Torsion tube stiffening This thread also shows pictures of real RSR bracing (along with 930 bracing)
PAGE 25 - The adventure home (planes trains and automobile...)
PAGE 26 - The Jack Olsen pose
PAGE 27 - Project Lessons learned
PAGE 28 - Interior and carpet installation
PAGE 29 - The car's 40th re-birthday party
The Dolly that I made to use to work on my car at home
Instead of buying a scissor lift where I always have to work on the car in the same spot, I made this stand that I can keep it on for the winter and roll in in the corner when I am not working on it. Here is the thread
Inspirational threads that got me started (from Mild to wild)
Jack Olsen's Black Beauty II - Black Beauty II
Chris' flat sided 73 - My '73 Hot Rod is Home!
Rob's ST Cafe racer - Robs 911ST Cafe' Racer
Reaper's 935 K3 build - Zuffenhaus 935 K3 Build for Fünf Gruppen
RUST repair threads
Fishcop's must read rust thread - http://forums.pelicanparts.com/paint-bodywork-discussion-forum/545166-restoration-my-69-911-a.html
Rockers and kidneys - 1967 911 restoration...becoming a T/R
This rescue thread is epic - 1968 912 junker reincarnation
My collection of rust pictures from other threads and other sources. Know where to look and what to expect.
Why windshield trim should be a regular maintenance item.
To "Glue" or-not-to "Glue!
Threads on upgrading or cleaning up cars that are already together
Now that my car is at the stage that it is at, I frequently refer to Jeremy's thread with lots of fantastic guidance on brake and suspension upgrades etc.
Well here she is -
Removing vapor canister from trunk
Although there are many suspension threads, I picked this one as a reference
'78 SC Elephant Racing Suspension Rebuild
A thread that I started when looking for opinions on selecting seats
Recaro Pole position thread
PART II - Update
Page 1 - Post #14 - Life-ing parts
Post #18 - the flywheel
Page 2 - Going insidel
Page2 - Saving it some more!
Page 3
- Cam specs
- 2.8 RSR oil catch can
- RSR twin coil mounting
Page 4 - 2.8 RSR historical perspective
Page 5 - Waiting for parts, the 914 diversion
Page 6
- Still waiting for parts, the Franklin Expedition
- Pistons finally arrive!
Page 8 - Twin plug ignition install - part I, mounting the CDI boxes
Page10 - Twin plug heads arrive!
Old 12-06-2015, 04:22 PM
puddy's Avatar
So I guess your not ready to just sell her off yet? I'd love to see your car in person sometime. Maybe in the spring we can meet up if you're in the GTA.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 12-06-2015, 07:38 PM
wayner's Avatar
$60k for the roller might motivate me. Otherwise I have too much unfinished business to walk away from it
Old 12-07-2015, 05:03 AM
I'll trade ya straight across, mine runs ad drives
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 12-07-2015, 07:48 AM
911T70's Avatar
Subscribed!
Been wondering what you decided to do.
Old 12-07-2015, 10:44 AM
wayner's Avatar
and so it begins...
Engine apart
Old 01-19-2016, 07:09 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
I most likely missed the post... but what happened? Engine blew up? Why?/How?
Any chance you can recap with a bit more detail? Or that is captured somewhere in the previous threads??
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 01-19-2016, 07:44 AM
wayner's Avatar
Good opportunity to put all the bad news in one place
Most of it is included in the original build thread (consider this current thread you are reading as part II of the build)
But fast forward through that thread and you will find things like this:
(which earned its own thread)
DANGER! install volt meter now!!
and this post 628
Almost crushed the car. Phew. Caught it before the wheel fell off
and this
Uh oh! What happened now?
But ultimately, this last page is the one that lead to the heavy lifting to be described in the thread that you are now reading:
What's that noise?
Which led to this speculation
doom and gloom
But ultimately, amongst all my pissing and moaning, Steve offered the best advice and that is what I am going to do
Originally Posted by Steve F View Post
Save it again!
I actually enjoyed this comment the most though. That doom and gloom thread contains some good comments. Sometimes you just have to laugh at yourself...
Originally Posted by impactbumper View Post
yep, cars ruined my life also. That cell phone throw was epic though
Old 01-19-2016, 07:58 AM
wachuko's Avatar
Okay... so I did read them all. I thought I had missed a post... I did go through those listed above when you first started this thread.
I got some additional gauges based on the situation you had with the battery...
Back to the car and the engine issues, glad you decided to fix it instead of giving up on it.
Drive safe!
1967 - Porsche 912
Old 01-19-2016, 08:19 AM
Retired, finally
SiberianDVM's Avatar
Such a great looking car; glad you decided to save it. Good luck as the search for the noise continues.....
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 01-19-2016, 08:37 AM
wayner's Avatar
Stay tuned for more details and more excitment as I document the steps
Old 01-19-2016, 08:38 AM
Welcome back with your '73! I won't forget your support when I started to take my project on, so cheers to you for sticking with it. Giving up is something you would regret forever, it just doesn't seem like you.
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 01-19-2016, 12:01 PM
wayner's Avatar
Starting to make some progress so time for some updates:
First of all, if you have followed some of the threads that I have listed above, you heard that ungodly sound my engine made. Very discouraging.
So discouraging in fact that I didn't even try to diagnose it. Instead I just assumed the worst, and scheduled a tear down.
Why such drastic measures you ask?
A friend of mine insists that this is still an old car and old car will always brake down.
I refuse to subscribe to that way of thinking. When I was road racing motorcycles many years ago, my race mechanic many years ago taught me about living components. Determining their life expectancy and scheduling preventative maintenance accordingly. Crank shafts were good for so many hours, wheel bearing for other hours.
My current engine guy Chris only half jokingly suggests that these engine will last 40 years "the way we drive them."
So, without a second thought, I'm preparing for the next 40 years before he gets too old. Also, I am becoming self efficient on the road, so everything in removing the engine from the car (minus the jack and jack stands) was accomplished using my on board tool set as a test to make sure that I had everything that I need before some mega road trip that I might never go on.
Old 01-29-2016, 12:43 PM
wayner's Avatar
Half an hour later...
Old 01-29-2016, 12:46 PM
wayner's Avatar
Thanks for the encouragement. My efforts were nothing compared to yours!!!
That's it! my first 911 restoration thread- '72 911 S back from the grave (maybe)
Wow!!
Old 01-29-2016, 12:48 PM
wayner's Avatar
Off to the tear down room...
Old 01-29-2016, 01:35 PM
wayner's Avatar
Leaking exhaust culprit. Could THIS be the noise?
Loosened fly wheel bolt. That hasn't been touched by a human for a long time. How did that happen?
Maybe this is the noise?
Probably, but I've already decided that we are going inside...
Old 01-29-2016, 01:39 PM
Banned but not out, yet..
RSBob's Avatar
Great threads and great source of information what a PITA about your motor but the good news is a fresh motor.
Gotta say, for months now whenever I see "saved from the crusher" since I don't know your track, I immediately see a car at the auto wreckers in one of those huge compactors/crushers.
Old 01-29-2016, 02:03 PM
911 tweaks's Avatar
WOW wayner... wicked bummah dude... pm me if you would like to talk on tele about where u r at on the tear down...
in all, this is part of the journey of owning a "classic or older" car... ALL of them have this happen sooner or latter...DOES NOT MATTER WHAT THE CAR BRAND IS EITHER...NO MATTER WHAT YOU FIND AS THEY ARE OLDER... similar to people... probably no fault of the previous guy who built/rebuilt what ever he did... just old(er) parts that fail and maybe... just maybe, something gave up the ghost & failed for who knows what reason... lmk so we can catch up... bob
I live for 911 tweaks...
Old 01-29-2016, 03:02 PM
