I'd sell off the goodies and pick up a 84-84 3.2 long block for about $5k with the Nickisel (sp) cylinders. Already has some of the best turbo cams, intake manfold, fuel rails. Just fit J&E pistons and almost there.
Corrupted by power
I would rather be driving
Yes, This should be easy to do on a bench with an adjustable frequency generator. Find the turbos and I can do the test. I can even start to code the .ini file for MS. This would be a custom mod to the code and I can almost guarantee there is not a specific example out there. However, the IAC and other controls work on PWM. It would be a matter of porting the code to the correct output and path.
I was looking into a mechanical system for variable boost geometry that I would drive with a servo using the MS. I am thankful for the identification of the VTG systems. Sure make life easier.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Corrupted by power
I assume since we won't use an IAC on a 911, that output could be reprovisioned for this kind of usage. Glad you can code - I work at a big software company, but my codin skills go as far as parsing code...can't write a lick, except for some basic SQL.
Yea, I know MS-II will do the trick, especially if going MFI. The only real advantage of the Sequencer is sequential injection. There are plenty of uys out there already running single spark COP set ups using run-of-the-mill v3 boards. Now to find the turbos - this is going to be a task as I have only been able to locate one new PAIR and you don't want to ). I am a fan of used parts and the discount they bring, as we all are. Someone out there is going to bin their 997TT eventually.
Corrupted by power
BTW, are you going with an ECU controlled BOV and pump enrichment? If so, there will oviously be even more custom coding to be done. Are there enough ouputs to control VTG, BOV and Enrichment from a v3 MS-II board?
Corrupted by power
![]() Nothing grates at the fabric of my motoring being more than continual rote recital of "there's no replacement for displacement". I say there is "no replacement for a unique creation." Convention has its place for those who prefer to see a beautiful picture vs. relishing the challenge of solving the puzzle in pursuit of the picture. Both are great and totally subjective...the former just isn't for me. My recipe: Add serious revs, mix it with positive manifold pressure, throw in some exotic alloys along with a healthy helping of currency and voila, nirvana. The road less travelled may have more bumps and tollbooths, but the scenery is FANTASTIC. That's why it takes me 3 days to drive to California vs. 12 hours. Hell, I may never even get to the end of a given journey, but damn wasn't it fun taking that last corner just a little too fast... - Edit - Did I ever mention that I have a real disdain for common plenum intakes? Even Varioram. ICK. Last edited by BARknucklehead; 05-28-2009 at 04:25 PM.. |
Max Sluiter
You must use the MFI
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Corrupted by power
You are such an enabler.
BTW, since we are completely off track and ignoring the bounds of sanity or putting limits on complexity, why not add water/methanol fogging to the mix? http://www.snowperformance.net/product.php?pk=8 ![]() Could MS-II control that, too? Yep... |
Corrupted by power
A decision has been made on turbo selection! I just sourced this bad boy:
Mitsubishi TD05HR-16G6-10.5T From The Lancer Evo VIII. ![]() ![]() ![]() ![]() Here's the compressor map - it's good for over 400HP: ![]() All of that power and lightning fast spool up for $300. Not bad. This is a dual scroll turbo, so I am going to have some stainless fun fabbing up the equal length pipes from my headers into the split mouth flange sometime soon: ![]() You'll notice that you need to keep the two exhaust banks completely separate until after gases exit the turbo to reap the benefits of twin scroll: ![]() Here's the O2 housing I procured used, as well. Amazing the things you can pick up used from the Sube/Evo sites for next to nothing: ![]() ![]() ![]() We are on our way... |
Yeah, that's a nice turbo. I'm running TE05-turbine turbo on my 2L 4-cylinder clunker and it reached full boost @ 2500 RPM before I fiddled with ignition and cam timing which made it a bit laggier. But full boost around 2500-2700 RPM will be fully possible on 2.2L.
How are you going to solve water mantle cooling? A short cooler loop with electrical pump? I wouldn't run it without water. P.S. Be prepared for slight boost taper on high revs if used with mechanical wastegate control. You can straighten up the boost on high revs with ECU-controlled PWD-operated valve but make sure you don't overspeed the shaft by asking it to boost 1 bar at 7000 RPM or such.
Thank you for your time, Last edited by beepbeep; 06-04-2009 at 04:03 AM.. |
2.1 liters, MFI, 540hp @8000 RPM's... it doesn't get much sweeter than this http://www.youtube.com/watch?v=zWeLuglJr9I Officially sub'd for the long haul on this one. Good luck!
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
Corrupted by power
Will use a rear fender well mounted radiator or heat exchanger. Quote:
Corrupted by power
3 restos WIP = psycho
I bagged the turbo above for an Evo IX version, which stock is both more efficient at spoolup and has longer legs on top. Couple that with the fact I just sent it out to Chad Block for a full performance build to BBK Lite spec and you have a turbo that makes 380WHP at 25 psi (1.7BAR) topping @7500 RPM on 93 octane in an Evo IX: ![]() Quote:
I have also settled on Brian's 1.5" headers. Ben and Brian have been saint's in dealing with my questions, BTW! Once the long block is done, I will need to finally commit on the induction and engine management. Electronic MFI or pure EFI? Water/meth injection to support 25psi or even...29 psi??? Oh we'll see! Anyway, the build is not dead and very much in motion. I'll start a fresh build thread once I start wrenching!
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Max Sluiter
I vote for the MFI. There have been a few people in the MFI thread talking about using a linear actuator directly on the rack to eliminate the chunk of metal ballast also called the regulator section.
Forced Induction Junkie
I think there's nothing more beautiful than an MFI setup. But........ If you're toying with water/meth injection, varying boost levels, different turbo combinations, go with the ITB EFI. You just can't beat the programmability of a computer controlled injection system. An RSR-style ITB EFI is a thing of beauty. Besides, the plenum and IC is going to block the view to the MFI pump anyway.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
There are still design challenges to overcome and although I do like the benefits of sequential EFI control, I am somewhat hesitant to have a big, honking fuel rail and EFI injector adapters below the TBs. Stealth is the main reason why I am considering MEFI (from this day forward, this will be my acronym for MFI w/ electronic fuel trim adjustment). One thing at a time, though. The longblock design is sound and the rest can come after that is done. So, stay tuned - once this litte project is out of the garage (a few more weeks), the motor build will begin. I'll also update my overall project thread on the car, but the motor will be a new thread in the Engine forum. I'll keep you posted.
Well, well the secret is out.
![]() I should have the coatings done shortly. I know you have busy with the paint project. I can't wait to see both of these projects going forward. I think we should hide the fuel rails in the airbox for a "stealth Madonna" type setup. Then you can have the EFI and vintage looks. Crap now I gave away a secret to my 2.5 build. Then you just need to figure out how to get the stock airbox to seal against boost. I think a feax filter cover on the front with turbo inlets on the back would be cool. This shouldn't be too hard with your liquid charge cooling.
Had to happen sooner or later.
![]() We should talk - I believe that I have that solution in hand.
I'm looking forward to seeing your maximum effort small bore turbo motor materialize.
