Corrupted by power
I need your Small Displacement Turbo Help! (Long)
Hi All,
Big lurker, first time post to the Pelican Turbo forum. I am embarking on a new project that is pretty atypical to most of the projects I read bout here, so am hoping I am not so far in left field that no one can help. I know there is no shortage of informed opinion and knowledge here, so fire away. Thanks in advance. I recently retired my little MFI ‘S’ motor and since I’ve always wanted to put a turbo motor for my early 911, figured I’d build one in the spirit of my old motor. Because of this, the typical turbo doesn’t appeal to me, meaning 3 liter and up motors won’t meet my desires. Frankly, they just make too much power! Yeah, that shouldn’t be possible, but I said it anyway. Please don’t reply with the standard “Just by a 3.3 and be done with it” comments – they aren’t going to fly; my course is set.The motor I am building is mostly specced and I already have most the parts to build the shortblock. It will be a small bore turbo, along the lines of the Baby RSR. Basic spec is for an 85mm bore x 66mm stroke, 2.3L intercooled engine. HP target is between 320 and 340HP @ 7500RPM, which calculates out favorably against my goal for boost at a conservative .8 BAR. The motor is being built to rev safely to 8000 RPM and my cam choice makes power to suit (see below). My final decisions are down to figuring out the turbo and IC configuration. There seems to be a lot of debate between twin turbo configurations vs. using a single unit, especially regarding the throttle response. Seeing as this motor can’t rely on displacement to overcome off boost deficiencies, I want to make sure that my selection maximizes spool up. During my research, it seems that the preference is for ball bearing turbos over journal bearing turbos, due to the efficiency gains they provide. Unfortunately, when matching my application for twin turbo applications, it seems the only ideally sized turbos that meet my needs are journal bearing turbos. So the decision looks like it is between: 1. Using two journal bearing small turbos like the GT15 2. Going with two larger, but less ideally sized bearing turbos like the GT25 3. Going with a single ball bearing turbo like the GT28 I was convinced that twin turbos are the way to go, but modern, water cooled turbos w/ variable valve timing like the WRX, Mitsu Evo, Audi and VW 2.0T cars all make excellent throttle response and power from one turbo. From my reading, I notice a consistent theme that most turbos today are most efficient over 1 BAR, typically in the 1.2 BAR range; mine is much lower, so efficiency should be down. Dilemmas, dilemmas… There is obviously a lot of tweaking that can be done on the A/R and compressor/turbine pitch to optimize any of these, but my question is: Given the above options, what would you do to maximize spool up for a motor like this and get similar throttle response to what these modern cars make? As far as full specs, here’s where what I already have: 85mm bore – Nickies w/ 7.5:1 JEs, thermo-coated 66mm stroke – SC rod journal grind, cross drilled Custom Dougherty turbo cams: GT2 intake with the DC43 exh on a 108 lobe center (@ .050” Duration=248I/242E, lift .485”I/.484”E, 108 lobe centers) Coated STD main bearings, grooved for cross drilled crank R&R chromoly rods w/ ARP bolts from LN Engineering, GT3 spec (same size as Pankl Ti-rods) 2.4T 7R case, fully prepped by Ollies: shuffle pins, oil bypass, drilled for cross-drilled crank Supertec head studs 2 liter heads w/ ‘69S valves, 39mm ports I/E, twin plugged 930 oil pump, race prepped Properly sized George Narbel headers ITBs Don’t have it yet, but will soon: EFI - Will use MegaSquirt II Sequencer system (waiting for final availability) Coil on plug Crank Fired Wideband 02, w/ MAP, TPS and intake temp sensor Apparently this ECU supports knock control and electronic wastegate/blowoff control – would love to integrate this I am not totally in the dark here. A similar motor to my spec (but with a less aggressive cam) produced this dyno run: ![]() Sorry to be long winded, but thanks again to everyone who battled through. Thanks! Last edited by BARknucklehead; 05-26-2009 at 12:25 PM.. |
Metal Guru
So, 320-340 hp out of 2.3 L at .8 bar?
I don't think you can get there that way. Better up the boost to 1.1-1.2 bar. You might need to run a lower static compression ratio than 7.5:1. As a data point, Porsche's first turbocharged racing engine had a 2.1 L displacement and ran 1.4 bar of boost, producing 490 hp @ 7600 rpm (source: Porsche 911 Story, 7th edition, pg. 269). Sounds like an interesting project. Good luck.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
3 restos WIP = psycho
1 Bar gets ~350HP, based on said calcs. @ ~12 HP per psi (basic rule of thumb, all other variables remaining static), this basically jives out. Water/alcohol injection would support this on pump gas. Maybe a future project? ![]() BTW, the 2.1 RSR still pencils out at 380 HP a .8 Bar, per my calcs...something is fishy.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 05-26-2009 at 08:57 PM.. |
Navin Johnson
I was going to build a small displacement turbo engine for my own car a few years ago....You are following the right path building the bottom end as robustly as possible.
Why are you limiting to 0.8 bar boost? Put a 0.7 spring in the wastegate, and use a boost controller to select your boost.. Why 85mm? 84 is standard 2.2/2.4 bore... You can get the nickies or Mahle cylinders... Then get a JE 2.4S piston.. It will be forged, and low c/r..probably 8.5:1 which is fine for a EFI controlled turbo engine.. This may be a more economical path I'd use other than 2.0 heads..go for some heads with as large port/ valves as you can get..More aggressive cams i.e. more lift and duration.. Also you make no mention of lightweight valve components i.e. Ti retainers. Also hi perf springs will be necessary if you want to spin the engine that high.. Narbel headers are mild steel...M&K exhaust has some interesting mods of stainless SSI headers, the secondaries are shortened and a v band clamp is welded on.. This is ripe for easy twin turbo apps. You could save a bunch of money by using a 3.2 manifold... in lieu of ITBs.. The Nth degree of performance will be realized with ITBs Are you going to twin plug the engine? I'm a bit confused on your description of the EFI set up... Will you be setting up the MSII sequencer for sequential injection and direct spark? If so in addition to the crank sensor you will need a CAS (cam angle sensor) you can take this obviously from one of the cams, or use an old distributor to provide the signal.. You can control a COP system with just a crank sensor though ... That MSII sequencer looks very interesting...I may have to pick one up.. Quote:
Sorry I strayed from which turbo to select...I'll ask Bill which turbo he told me I should use when I was going to build a 2.0 turbo...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Not an expert but here are some thoughts.
7R case starts reaching its limit at about 270hp. At the heat of a turbo with severly increased combustion pressures and you might be taking a risk. Might be better to find an early sand cast aluminum case if durability is important. Small displacement, short stroke, low compression, cams that will support a usable power band up to 8000rpm -- and I suspect low end power and response is not going to be in the cards. For example, a K27-7200 turbo supports 320 hp. Boost starts to come on at 2500 with full boost at about 3200rpm on a 3.3. Put in on a 2.2 and boost will start at about 3700 rpm with full boost at 4500rpm. Further, you will not likely get low overlap cams to work well at the rpm you want to reach. Thus, boost will come on later with the same turbo. Also, you may need a larger lower restriction hot side for less back pressure so there is less hot gasses being pushed back in through the exhaust valve and past intake valve up into the intake manifold. Think a step beyond a 911S 2.2 (906?) in terms of power band and throttle response. You will probably want the turbo and cams to come in at about 6k to work right. No reason to go twin turbo that adds complexity and weight and you will be looking for turbos that make about 160hp each. What would be fun would be to run an MFI set up with your 2.3 turbo set up. The best. |
Crotchety Old Bastard
Interesting project.
How far outside the box are you willing to go? With engine management combined with tiny displacement you can try something really different - a single VNT from the 996tt. Max reduction in lag and just about the perfect size for 0.8bar from 2.2L engine.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Corrupted by power
TimT, I was really hoping you'd chime in. OK, one thing at a time...
Corrupted by power
Damn, jackpot! 911ST, I was hoping you'd chime in, too.
Corrupted by power
Holy Trinity; thanks RarlyL8!
From what I can read, the stock 996 turbo is the K16; is this correct? For some reason I thought the VTG turbo were Borg Warner. I thought these were 997 only, though. Any clarification would help. Last edited by BARknucklehead; 05-27-2009 at 07:56 AM.. |
Corrupted by power
Can you explain why 8.5:1 is OK when it sounds like getting even .8 Bar at that CR sounds like it would be impossible? What are the variables that would allow this with EFI? Ignition mapping w/ load sensing, etc? Fuel enrichment for charge cooling? Love to hear some toughts on what you gain/lose at this static CR... |
I thought about the VAT also. Historically managing them was out to the abilities of most. I do not know if that has changed. This is the only way to reach the goal of low rpm full boost and carrying 8k I suspect.
As to the hot side I was referring the the turbine, not the tube size. If it spools at low rpm it will make a lot of back pressure up top. With the cams you will need to carry 8k this should be an issue. Talk to your cam builder. Trying to reach boost by 3k and pull to 8k is a sizable task. Did SW know you are going w a turbo on you R case? We are talking a lot more heat and potently expansion. Having said that there has been one builder I read about the built a 2.7 twin turbo he used to drag race that made big HP w/o a problem. Road Racing might be different. Best of luck and look forward to the project. |
Corrupted by power
I assume managing the variable vanes is through electromechanical control, not by pure mechanics (like a bypass). I will have to research the ECU capabilities more to confirm that this isn't beyond my capabilities - I am not so skilled as to write custom code for vane actuation. |
Corrupted by power
OK, looks like I cleared up a misconception on my part. Only the 997 uses VTG (variable turbine geometry), not the 996.
As a recap, these adjust flow by altering the air incidence angle upon the turbine. Basically, the 997 Borg-Warner VTG turbo is just a more modern version of the variable vane technology that was piloted in production back in 1989 in the old Chrysler Shelby CSX turbo POS. Older variable turbos were indeed mechanically actuated, but were unreliable in gasoline engines due to high exhaust temps (compared to diesels). The new Borg-Warner VTGs use aerospace materials and thus are very reliable and make great pressure. The 997 Borg-Warner VTG appears to be computer controlled, but have yet to verify...anyone know for sure? One other note: apparently "variable vane", "variable turbine" and "variable nozzle" turbos all refer to the same thing. |
Sorry about the 996/997 confusion. Yes 997 is the variable speed turbo I was refering to.
I'm sure it can be made to work with less complicated engine managment electronics.
Corrupted by power
I'd bet that the 997 vane actuator (and the VNT-25, for that matter) is analogous to a stepper motor, which MegaSquirt can control. BTW, those 997 turbos are like hen's teeth - you pretty much have to buy them new, which is an EXPENSIVE proposition. |
Navin Johnson
Yes better control of all aspects of the engines operations..I'm going to delve further into the Microsquirt sequencer and what it can do.. It may have available channels where you can use knock sensing. With 8.5:1 you will get crisper off boost throttle response.. though maybe not so much with a small displacement engine. I just put that out as anecdotal..We have built a number of 8.5:1 turbos... some with CIS.... and haven't experienced problems that were purely c/r related... The new Porsche 997 turbo runs 9.0:1 cr Granted they are water cooled... .. On a related note our 935 clone is 8.7:1 and we sometimes run it at 1.6 bar... usually it runs at 1.2 bar...The only failure this engine sees is if it is over revved... other than that bullet proof.. Back to the engine management side.. you can run fat in areas of the map to keep EGT in check.. Your engine will be a real fun engine... especially in a light car... My car weighs 1846 wet
Corrupted by power
And to think I thought I needed water injection to get over 1 Bar...SICK. ![]() I will probably come in at 2100 lbs - this car will have some creature comforts, albeit not many. Mostly carpet, engine pad, some tunes, etc. All steel body hurts weight... Last edited by BARknucklehead; 05-27-2009 at 09:18 PM.. |
Stole this pic from another thread of the MFI pump with a boost enrichment can mounted on it incase you want to rethink you EFI idea. I would keep the ITB's w the pump mounted in its original location and put the IC on top of every thing.
Or you could mount it off to the side like the factory did. ![]() |
Corrupted by power
You guys are killing me.
I would rather be driving
I have looked into this too. I have spec'd a similar build for the next year or so.
btw, the 997 Borg Warner VTG turbos are electronically operated. I have not been able to figure out if they are direct voltage or PWM actuated. yes, Megasquirt can run this system on either a boost value, rpm or possibly both depending on your ability to code. You would use the configurable output to run the system. Now just need to figure out how to fit a ducktail under the decklid for 350 HP of hidden, sleeper fun! Off to continue looking for a donor engine. FYI, I don't think you need to wait for the sequencer to arrive. The standard MS unit should function just fine - especially considering the rpm range where you will be building boost.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
